Filling in gaps in wall shadows
Hello all,
I was making an indoor/outdoor map with a little cave, and I ran into this problem with shadows and I just can't come up with a solution. I want shadow in the circled areas, but I can't draw a wall to cast shadow past the map border, nor do I want to fill my cave with random chunks of wall to fill out the shadowy area inside.
Does anyone have tips on how to accomplish this, or is there a tutorial floating around that I haven't found that touches on this subject? Or alternatively, is there a good way to draw all shadows by hand?
(also excuse the imperfections, this is basically just a test map I slapped together to learn the things I want to use in a real map.)
Any way, your solution works perfectly for me, thanks
I prefer the transperancy effect because it lets me add some color to the shadow.
Cheers,
~Dogtag
But I've noticed that all polygons with a "Solid XX" fill disappear when I redraw. Any idea what that is about? I made sure they're on the right sheet.
Also a more artistic question: what looks better, black or dark blue shadows? I paint a little, so I'm used to adding a bit of blue to shadows, but I'm not sure if I like it here.
As for the artistic question, they both look good to me. I think the qualifying factor would be what sort of mood/atmosphere are you looking to create. The dark blue seems a little more eerie and otherworldly to me.
Again, I think they both work well. Good choice on the fade and transparency.
Cheers,
~Dogtag
Thanks for the help and the feedback.
