Having problems with dungeon lighting effects
I've carefully read through the posts on lighting in the forum, plus Joachim de Ravenbel's paper on light effects, but I still can't get the light effects to work properly in DD3.
I end up with a completely black dungeon map except for the torch sconces.
My Sheets are arranged as follows:
LIGHT
FLOORS
WALLS
SYMBOLS TORCHES
LIGHTS FINALIZE
with Wall Shadow, Point Light Setup activated in each sheet and Wall Shadow, Point Light Finalize in the last sheet.
What am I doing wrong?
LIGHT
FLOORS
WALLS
SYMBOLS TORCHES
LIGHTS FINALIZE
If you could upload your map (or one that displays similar problems), it would be much easier to diagnose the problem.
If you add the light effects *first*, then apply the Wall Shadows to the sheets, the whole dungeon ends up dark.
Here's the room with shadow effects turned off.
You ought to do a tutorial on light effects in DD3 and post on YouTube!
