Fading contours on contours
Hey Guys,
I am fairly new to working with CC3+ and I have encountered a small problem. When I place contours on contours the second one does not fade in, even though I use inner fade.
I've read through some of the discussion and the answer seems to be to use different sheets, however even if I use separate sheets for this the contours are not affected. I can not seem to be able to delete them either.
Thank you for your time and assistance,
Orkash
    edited July 2017
    Make sure your contours are actually placed on different sheets (Use LIST on them to check, drawing tools normally are set to choose their own sheet, so creating a new sheet, and even selecting it before using the tool won't necessarily mean it will go to that sheet), and also make sure that all these sheets actually have the fade effects set.
    Fade only works on the total outline of all entities on a sheet, and not individual entities, which is why only the outer contour fades when using a single sheet.
