Turn off Offset
ScottA
Surveyor
Okay, another question. I'm trying to populate my city with buildings, and I'm having no end of hassle with the offset command. I don't want it -- I want to just place everything manually. As I'm placing building symbols along roads (lines), I'm having problems with them offsetting at weird angles, etc. I understand that happens with repeated use of the same symbol, and as I'm trying to fill a warehouse district, I'm using lots of the same symbol. I see in The Tome of Ultimate Mapping how to do everything with offset command except turn it off! This one has me pulling my hair out!
And I mean ANY polygon.
It used to drive me nuts when I was doing Merelan City. In the end I had to hide all but the sheet with the road on it, and the sheet I was placing the houses on. LOL!
If you start turning things off with the smart symbols you will end up having to manually rotate and align them, which is far more of a pain than just hiding the sheets you don't need to see so that you can use the smart behaviour in relation to the actual road.
Would it perhaps be better if you could click the road in a place that you knew was clear of intersecting polygons and lines, and then be able to move the aligned house along that road, I mean as well as being able to move it closer or further away from it?
It's more trouble to click a clear area and then move the symbol down because once you click, the Smart Symbol offsets perpendicular to the entity at the point you clicked. You can't move it along the entity, just toward or away. You'd have to set it and then move it. Blech.
Your solution is simple and elegant. I just wanted to clarify for folks that the issue isn't the offset feature so much as the auto-align feature.
That wouldn't stop them from reacting to the presence of other lines in the map that aren't roads, of course, but in most cases lines that are not roads are usually borders or rivers, and are more visible than say, a polygon with a an edge fade inner on it.
Edge Fade Inner is really only an issue if you have effects turned on, and even then it shouldn't be too much of a problem unless the fade is really high. But, if you have effects on and it's a problem for some reason, I'm sure the Attach mode and the various attach modifiers can help to make it a non-issue.
Frankly, I think your suggestion to hide sheets (or layers) that might cause interference is a quick and simple solution.
