I do notice, however, that the shading of the cliff does not match the one of the rail cars. The light source for the later seems to be in the top left corner, whereas the light source for the cliffs seem to be in the top right corner. I assume that changing the light source on the rail cars would be a bit easier.
They are a little tricky to align, but you can mix them up fairly easily. I added some other rock around the edge to help blend it in. I think that the reason you've not seen them before is because CC3+ maps are generally on a larger scale.
The railcar... I found a smaller image on the web and basically traced portions of it, enlarging it as I did so. Then I cut and deformed it multiple times in order to make each wrecked car. Making an image look bent is actually a bit of work
Thanks, Jensen
Outstanding
The cliffs come with CSUAC, I think - http://www.vintyri.org/CSUAC/download.htm
Tim
