CC3+ Update 10 Error
I was going to install one of the new CC3+ Annuals (Vol. 4) and got told I needed to update CC3+. I downloaded Update 10 and got an error message during the install.
It says cannot create the file C:\Program Files\ProFantasy\CC3Plus\Images\StripingCA106.png A directory with this name already exists. Cancel the install and try again.
I clicked Abort and then it went and did some install of a a font and got the menu key'.
I checked and noticed I had installed Update 10 several weeks ago. So I'm not sure why the annual said I needed to update CC3+
So do I need to uninstall something or run a repair or something?
    I had copied an Annual issue over that hadn't been updated. And I got a similar error when I installed the Annual after it was updated. I selected Ignore and it worked okay. But I think Remy should answer to. He knows more about this than I do, or DogTag could help.
    edited April 2017
    The installer should overwrite existing files. Did you have that file open in another program or something perhaps?
    In any case, I recommend running Update 10 again and doing a repair install (if given the choice). If you continue getting the error message, I recommend you contact support
  • My problem with the latest Update is the factthat CC3+ crashes whenever I try to fractalize an existing entity, though no problems drawing a fractalized entity. Trouble is, I have no control over the fractalization details. Hope this gets fixed soon.
  • Sure, I will do this, but others have also had this problem.
    Yeah, me to, fractalize causes a 'close program'. My apologies for not mentioning it earlier.
    I didn't have any Profantasy product open, except the installer. I had to tell it Ignore to get it to continue installing an Annual when I had copied one issue of symbols over all ready.
    I know that it was a problem for me because i had Perspectives installed and thought the next update would include a fix for it. Until then, I removed Perspectives and it works fine - which isn't a problem for me since i rarely used it to date.
  • Jay_NOLAJay_NOLA Traveler
    Sorry if this shows up again.
    My reply post got deleated, then showed up again, and then got deleated again.
    I contacted support. The updater installer was still doing it even on a repair install.
    Ralf said that the file isn't essential and it ought not to even be in that location. So if clicking ignore works just to do that.
