Multipoly disappearing
Lorelei
🖼️ 46 images Mapmaker
So my usual method of creating a frame doesn't seem to be working on a particular map. When using the multipoly my new poly disappears. It's there as i can select "something" but when trying to change fill style or anything else with it, i've got nothing. I checked all sheets and layers are not hidden or frozen. What the heck might be happening on this map? I went to try on another map, no problem. No problem on a new map either. Just this one. Anyone have an idea what is happening and what i might have done to cause it so i can remedy?
Any chance you could share the FCW?
Also, what if you copy a multipoly from one of the other maps you just tested and paste it into the problem map? Does that work? If not, what if you copy the problem map — minus the multipoly border — into one of the working maps?
