Hotkeys for CC3+
Is there a list of command and the hot key equivalent? I have a fancy mouse, and I'd like to map some additional commands to the buttons on my mouse. Some desired examples would be, info list, delete, change properties etc..
    I don't know if there is a list, but all hotkeys are visible in the menus. You can also edit the menu files to add your own hotkeys to any command (Note that if you do this, remember to edit all the menu files. If you only edit the overland menu, your changes will only be active when this particular menu is active).
    There's also a list of all the text commands in the Tome, if you have that, you can probably feed your mouse the actual text command instead of just a shortcut key (You can also see these text commands in the menu files if you don't have the tome)
