How does one stretch a raster object?
Topdecker
Traveler
I have a double-wide door and a single-wide set of stairs. When I try to STRETCH the stair symbol, it just moves around, unchanged in appearance. I take that this means that I am doing it wrong - probably using the wrong tool for the job.
Imma about to go find that symbol, use something like gimp to resize it, and then import the fixed image. But that seems a bit extreme if it can be stretched inside CC3+
How does one resize a symbol? Apologies in advance for the newbie question
When placing the symbol, you right-click and select INDEPENDENT X and Y and then scale the appropriate axis. You now must click MORE and then place the adjusted element.
