Sheets order
Hi. I've read on the pdf manual that entities you put on a sheet will be displayed above the entities that are placed on lower layers. Here I have a pic of a landmass I've drawn and some "default sea" (in the pic you can't see it because is merged with the sea portion of the default template of overland which I haven't covered with landscape). Why the sea, altough I've moved it to the last bottom sheet appears to be above grid and background land? If I hide the sheet the map appears as I would, but it's supposed to be the same without hiding it as the sea sheet is the last one. Am I doing something wrong?
