World Map (x2) Malat
Out of the blue a setting idea hit me over the weekend. A setting that requires at least two world maps several thousand years apart (for reasons that will become apparent). I only seem to be able to attach one image to the post so I'll follow up with the second map immediately.
I've given it the provisional name of Malat though that might change.
This is the earlier period map and I've already started with the mountains. I'm wondering if they look okay?
Becka
Becka
Also this one doesn't have mountains yet.
Becka
Thanks for sharing,
~Dogtag
By the way, you can add more than one image to a post, but you need to add the first image and submit the post, then edit your post and you can add more images.
I've added the mountains to the second map, mostly a copy from the first but I have added a few more.
Becka
