Placing Additional Symbols Into DD#
Aircop
Newcomer
How can you place your own symbols such as different levers into the symbol files for DD3? I have done this and when I place them they dsiappear
Note that you usually want to do this on the symbols in the actual symbol catalog, and not just the symbols in the current map, but also note, that since symbol definition is copied from the symbol catalog to the map upon first use of any individual symbol, if you change a symbol in the symbol catalog, it won't affect those symbols already used in the current map.
If you don't want to mess too much around with this, you can also just remember to have the correct sheet active when placing them. Symbols go to the current sheet if nothing else is specified.
