Rectangular JPEG export saves more than neccessary
Whenever I try to export my (very large) map in 4 sections and use the rectangular JPEG export, it saves a wide line of the image above the lines drawn by the coordinates I input as corners. I have no idea why this is happening or if this is even supposed to happen, but its very annoying since I can't effectively assemble the map in post.
    Enable the 'Crop Image to Aspect Ratio' in the export options dialog. If this isn't checked, CC3 will export additional parts of the image to satisfy both the horizontal and vertical resolution you have specified in the export options dialog.
