Drawing tools going to wrong sheet
This is a pretty straightforward problem, but it's quite frustrating and I have no idea what the cause could be, let alone a solution.
I have the "Areas: Variacolor" drawtool in Modern City set to use the current sheet (and the current layer), as the layer and sheet I want entities created with this tool to go to will depend. I have it set up like so:
But when I actually use this tool, it ALWAYS places the resulting entities onto the "Buildings" sheet. It doesn't matter what sheet I have selected, and it also doesn't matter if I select my sheet, then activate the tool, or vice versa. Always to buildings. I have closed and reopened CC3, but that's all I've done as far as troubleshooting.
Am I missing something? Isn't "leave blank to use current sheet" supposed to make it use whatever sheet is selected? If it is, then does anyone have any idea what could cause this?
It also appeared quite suddenly, just a little while ago. I made an entity on my map with this tool, and it went to the "Areas" sheet as I wanted, then suddenly, the next time I tried to use the tool (a minute later), that entity went to "Buildings", and it's been stuck like that ever since.
