CG January 2017 Challenge: Misty Mountains (Map a Song) WIP
![LadieStorm](https://forum.profantasy.com/uploads/userpics/301/nHGOWB3NBS52H.jpg)
Greetings everyone!
I know, I've been away for a while... between the holiday gifts I had to make, and my normal internet cafe moving to a new location... I haven't had much time for mapping or getting online. And I will hopefully be moving in the next month or two, so I won't be online as much... but I'm still mapping when I can. This is a map I've started for the Cartographer's Guild January 2017 Challenge : Mapping a Song. I've chosen to map the Misty Mountains, from the Hobbit. I'm not done with it yet, but here is what I have so far.
Hey you! Long time no see over here. There are more trees here than I would have thought there to be. anyway, I can't wait to see it finished either.
Nice map. I find the close-ups using overland symbols interesting. Makes nice use of the fact that these symbols comes in rather high resolutions.
I've already commented on this one over at the Guild, but I'll say it again here - great start
As much as I globally like this map, and am impressed with the result you've obtained, I have two small issues not on the map itself, but on its suitability for the challenge:
- To me, this map is more about mount Erebor and the Iron hills than about the Misty mountains themselves
- I think the song is very dark and deep, while currently the map is more light-hearted. I don't really know how to change that though. Maybe by toning down some colours?
Here is my FCW
Other than that maybe the frame has somehow managed to end up on a layer (not sheet) that is hidden?
something is definitely going screwy at my end, then....
To work around this problem, in the Bitmap Options dialog, simply uncheck the "Restrict Image to Map border" option. But the real permanent fix is to erase the current map border (on the MAP BORDER layer) and draw a new one in the appropriate location.
I remember seeing advice in a dungeon circumstance to instead copy the dungeon onto a new map of sufficient size, but it would seem easier to just erase/redraw the map border in that circumstance.
Merelan City started as a 5000 x 5000 unit map, but with the addition of the frame it became a map that was 5600 x 5600, and which I had to export as a Rectangular Section JPG, giving coordinates -300,-300 to 5300, 5300 to define the render area.
In the situation where the map just seems to keep growing, having a frame is almost a handicap - though I can understand that its more convenient to have one there to define the extent to be exported if you are not in the habit of using rectangular section exports.
As to why I have to have the whole map showing - it takes 5 minutes to move the view on Merelan City nowadays with all the effects turned on ready for rendering
