Does anyone know if someone has redrawn the Iron Crown Enterprises full map using CC3 and if so where can I find it? I have attached said map to this discussion.
That full Middle Earth map is definitely a BIG improvement on the map usually included in the LotR books. The book map understandably only covers the area where the action took place, which was basically a big rectangle and extremely lame-looking. Even on that big map, it's not hard to spot the "Tolkein Rectangle".
Tolkein was a fantastic writer, but a very poor cartographer.
Now that I've said that, someone will probably give you a definitive answer
I haven't got the map drawn in full or as an exact copy of the original.
However i do have two versions the map, split into four.
Version one is a combination of the continent map and tolkiens NW map.
Version two is a combination of the continent map and updated B/W continent version published in some modules.
