Annual Numbers not at webpage?
Robak
Newcomer
Hello everyone,
I ordered most of the Annuals.
I would like to ask if it is posible to show the Styple number also on the Weppage associated with the style.
Every time when I would like to start drawing a map I first go through the Annual Styles on the webpages https://secure.profantasy.com/products/sub.asp.
When I found a style appropriat for the actual map ( http://www.profantasy.com/annual/2015/january15.html ) then I start searching for the guide in my annual Folders.
I know the styple is January 2015.
Now the Annuals are splited in CC3 and CC3+ Annuals which are located in different folders.
Each style has his one folder. And each folder is named by a number.
But which number is January 2015?
We need to calculated.
2015 is the 9th annual and January is the first month so we calculated the folder number as (9-1)x12 +1 = 97.
And Yes I found the mapping guide in the folder 97. Yeh!
But I think if would be easyier to find the style guide by showing the number at the webpage.
with best regards
Robak
with best regards
Robak
For example, if you want to create a map using the January 2015 annual style (OSR Dungeons), the mapping guide is named CA97 Mapping Guide - OSR Dungeons. Also, when you start a map, select Dungeons from the Type list, choose Decide settings for myself, click Next, and then select Annual OSR Dungeons from the style list.
Still, if you really need the numbers then, as you mentioned, you can figure them out fairly quickly, although it does take a little math. There are 12 issues a year and the first annual was for 2007, so the issue numbers for each year are:
Vol. 01, 2007: 1 - 12
Vol. 02, 2008: 13 - 24
Vol. 03, 2009: 25 - 36
Vol. 04, 2010: 37 - 48
Vol. 05, 2011: 49 - 60
Vol. 06, 2012: 61 - 72
Vol. 07, 2013: 73 - 84
Vol. 08, 2014: 85 - 96
Vol. 09, 2015: 97 - 108
Vol. 10, 2016: 109 - 120
Vol. 11, 2017: 121 - 132
I hope that helps.
Cheers,
~Dogtag
That said, the first year issues should be easy to match up with the appropriate month using just the issue number.
~Dogtag
I agree it might be helpful to add issue numbers to the Annual Volume web pages but whether that happens or not, you can search for a particular guide on your computer using the title. Windows has a search feature that can help you find the PDF titles, though I personally use the Everything search utility to search for files on my computers.
