Exporting Maps from FT3 to CC3+ w/Image Climate
Hello people, this is my first time posting here, but I've been using FT3 for a while and I'm starting to use CC3+. Specifically, I've made a world map of a planet from a story of mine in FT3 and now I want to export the map to CC3+ to continue working on it. I know how to export from FT3 to CC3+, that's not a problem, but I've only been able to export the map showing altitudes, temperatures, rainfall, or climates. I have a custom made image climate shader for the map, and I want to export the map to CC3+ with it colored according to that image climate shader.
So my question is, is there a way I can export my FT3 map to CC3+ with it colored according to my image climate shader? Or alternatively, can I use image climate shaders in CC3+ to change the colors of my map after I export?
When you say "export an image and then insert that image into a cc3 file," do you mean export an image of the image climate shader, or export an image of my map using the image climate shader? Will an ordinary JPG image work, or do I have to use one of the special export options within FT3? How do I insert that image into a CC3 file? I'm not that familiar w/CC3 yet.
Generally, since the way you represent a map is usually quite a bit different between FT3 and CC3, I recommend exporting only coastlines from FT3 and start your work in CC3 from there, applying one of CC3's own styles to the map.
