So....whats up with the autosave
Three hours in and the whole page just disappears except the grid. All I was doing was adding doors. What the blazes. Is this a common occurrence? When I start creating my world instead of a dwarven retreat will I get days and weeks worth of work just instantly wiped out.
I turn off autosave and save as filename01_001, work on it, save as filename01_0002, etc. until done. That was I can go back furtherr than undo can handle if I need to.
If there is any room for a tech suggestion here, it might be that the autosave could be set to save under the same filename as the file, rather than the same name for all files, so it is possible to recover from a disaster that happened last week, or last month, but with all the annuals being converted and so much else going on, that would be fairly low on the list of priorities.
