Sorry for this new question: troubles with copy n paste...
I m working on my last map...a detailed map of a specifical area....
This what i need...i have to work on this specific portion of my continental map (the one i posted in the forum somedays ago...)
i selected only (more or less) the portion you see in the box above (i copied n pasted by photshop, starting from a jpg file)
And a second question...how can i know the size of copied area to create a proper window in the new cc3 instance, to male the copied area fit in the new window?
You'll need to trim the parts of the entities that extends outside the map border. I'll recommend having a look at the various editing mechanisms in the Editing chapter of the manual, it describes to to trim and edit entities.
To get the size of the area, use the distance tool found in the Info menu.
but why the river background wasn't copy???
i still can't understand it...
Usually, this is just as well, because you will normally paste it in to a map that already has a background, but if you want it, just make sure to manually select it when copying, remember that you can continue selecting after using the selection window.
it works properly....
i m too much into the classic copy n paste system....
i trace inside the map....but if i select erase strument, it deletes everything anyway...
i tried following the manual...but can't understand how it work...
I could trim river...n borders....and i was able to remove landmass over the map box...
but i can't erase trees, saving those inside and tillages....
i use trace, to save them, but it doesn't work......
really very hard for me...
You could delete the entire group of trees, select vegetation from the symbol icons, and place trees to cover where the group was.
Also under bitmap fills, you can change the size of the pattern beside 'Scaled'.
