Grid not matching up.
I need some help. I am trying to have the Grid 10'x10', and the tile match up. But it wont... What do I need to adjust?
Please see attached CC3+ file.
Thank you for your help.
I'll instead recommend that you use the flat stone fill instead of the tiled one, and then use a solid black grid with a gridline width of about 0.05, and apply a weak black glow to the grid. This will cause a similar effect to using the tiled fill, but since it uses the actual grid for this task, you won't have to deal with the issue of not lining up.
If you want to, you can also have two grids in the drawing, one purely for the effect, and the other your normal grid.
