(SOLVED) Removing the map outline
blueFire
Newcomer
Every new map I am starting with CC3+ has a white outline around it (see attached). How do I remove the outline?
Jason
Jason
Make sure 'crop image to aspect ratio' and 'restrict image to map border' are checked. Some templates in CC3+ require one of those to be unchecked.
There is a second border also which is on the text layer. You could select each of these and delete them. Or just hide the layer.
Thanks to everyone for the help.
Jason
