Tools disappeared on sides
Hey all,
Just got the program about a month ago and have been working hard on learning the program. It's pretty cool and having a blast!
However, I opened CC3+ up and all my tools disappeared from my side bar...like default landmass, default river. I can click over there and sometimes get an action, but I can't see the actual symbol. For example, if I wanted to hit the eraser button, I can't see where it's at, but if I blindly click for it, I might get lucky.
I went up to View, and scrolled down to Toolbars and messed with that, but it does nothing. The only symbols I can see are the tools under Options (mountains, apples, etc.)
Any idea how I can make my tools visible to the left and right of my screen? Thanks!
    edited November 2016
    Hi Malrex. Welcome to CC3+ and the ProFantasy forum.
    Have you downloaded and installed the most recent update? Currently, it's CC3+ Update 9. If you haven't, you can get it from your account page. I recommend you install it (and all ProFantasy software, really) by right-clicking the setup file and selecting "Run as Administrator" from the pop-up menu.
    If you have already run the update, you may want to try it again and choose the Repair option.
    I don't know for sure if it'll work, but running the update has helped with some other invisible button problems in the past.
    I hope it helps,
    ~Dogtag
  • Thanks Dogtag. I will try that when I get home and report back.
  • Yep, finally had time to try that. Thanks!!! That fixed it!
    Back to happy mapping!
