Perspectives 3 - Cut hole in a wall?
Hi Team,
Is there functionality to cut a hole in a wall with PER3?
Like if I create a room and want a door in one of the front walls, putting a door symbol looks wrong because the wall obviously blocks the back of the door.
I would usually break/split the wall and move things around but I can't figure out how to work with the walls at all. Node Edit doesn't let me move a wall.
I'm surely failing at an epic level :D
