SS1,2 & 4 icons not showing up
I uninstalled everything Profantasy.
I installed CC3+, CD3+ and DD3+.
Then I installed SS1-3+, SS2-3+, SS4-3+. Problem is that I used to (CC3 time) have a SS4 icon, but now with CC3+ the SS icon isn't showing up.
I've gone through this twice (uninstall everything and then re-install) but the SS icon(s) aren't showing up.
Am I doing this in the wrong order?
    Try to re-run the latest update (Even if your CC3+ is already at the correct version, since it also fixes files copied in by the add-ons)
    If that doesn't fix it, run the CC3MenuConfig.exe file found in the CC3+ data directory (close CC3+ before running it, and note that it doesn't produce any output and finishes real quick)
    Also note that SS1 and SS2 doesn't have any toolbar icons.
  • If you haven't downloaded and installed CC3+ Update 9, do so.
    If you have done that, run the update again. That should fix the problem. It occurs because these older add-ons run configurations that no longer are up to date. Running Update 9 (again) should fix that.
  • Thanks for the info. I'll try those suggestions.
