transitioning terrain
I have a question about terrain.
I am making a map that goes from deep water, shallow water, wet sand, dry sand a cliff face then a plateau.
i was able to blur the lines between the deep water and shallow water, but cant seem to with the dark ( wet) sand and light (dry) sand. cant find proper sheet. Also, the floor cliff texture leaves something to be desired. Is there another technique someone recommends?
Note: I am not good with this or any other drawing program. I have been able to create some basic maps, but over technical speech will go right over my head :)
Thanks!
    To soften transitions between different type of terrain, you need to make sure they are on different sheets. You may wish to create extra sheets yourself for this purpose, and move your entities there. Then, you need to set up an Edge Fade effect on the sheet, this will soften the edge, gradually blending it with the terrain on the sheet below.
