How do I take a zoomed portion of a dungeon map and copy it to be pasted into say.... the Windows Paint programme? Can these maps only be viewed in their quality state by a CC3 viewer?
Turn on sheet effects if you have any applied.
Go to File -> Save As....
For file type, select BMP rectangular section from the pull down list.
You will be asked to pick two opposite corners in the command prompt line.
Save the file (it will save as a BMP) and open in Windows Paint. More info here: http://www.profantasy.com/cchelp/cc3_reference/export_import/hlp_dbx_saveas.htm
Hope that helps.
Edit: You may need to set the export options to something like 1000 x 1000 if you are saving a square area of a map, for example. More info here:
http://www.profantasy.com/cchelp/hlp_cmd_jpegopt.htm
