Creating a Symbol Set
Lorelei
Betatester 🖼️ 46 images Mapmaker
Ok, i have stupid question....but I am currently discussing making a map for a potential client in the Netherlands - I would be making a regional map and they would then like to be able to alter the map in the future - which means, obviously, i sell them full rights to said map. My question is this....I intend on using ONLY CC3 symbols on this map, using multiple Annuals on this map - if I create a Symbol Set with all the symbols i incorporate into this particular map, would the client, if they didn't have the Annuals, be able to utilize the map if i sent them the .fcw and the Symbol Set itself if they do not have the Annuals available to them? (Does this make any sense?)
If they don't have the annual issues you use to create the map, I'm afraid they'll see red X's in their FCW wherever you use the annual symbols or bitmap fills.
Now, that won't happen if you include the actual symbols and fills (PNGs/BMPs) in the proper folder structure and they install them in the proper folder structure, but I'm willing to bet that providing the symbols themselves would violate the license or terms of use for the annuals (like packaging a commercial, licensed, font file with a document), so that's something someone from PF should address.
There was a thread on CG just a couple of weeks ago. Someone passed on their original unflattened (layers welded together and no longer editable) file along with the exported image. He wasn't acknowledged as the author and no mention was made of his having drawn the map anywhere.
The general consensus of opinion was that the original should never be handed over. Its normal for the person buying the map to return to the original cartographer to do any alterations. All the PS users on the Guild only sell the exported images.
Tomorrow I shall have some negotiating to do or I will pass. Thankfully WK, will be giving me full credit for the extensive project I am doing for them and their products can be found in many FLGS throughout the country. I'm good with that
Thanks for having my back.
Hmmm... but what about pngs of different resolutions ? That way the could 'zoom in'.
However, if you really do decide that you want to sell your original FCW files, then you could tell the clients that they need to buy and install such and such ProFantasy products to be able to use your maps in FCW format.
That still leaves one problem, of course. If your maps are done with CC3+ and you are using material from annuals that you have converted yourself, that might be more than your client can handle, because you wouldn't be able to distribute your conversions legally either.
Which reminds me.... Do any of the annuals have modern symbols? I may be in need of an air traffic control tower. And a way to create a runway...
Good luck with it Storm
Your clients can download Vol. 3 and use it, just as you can, making red Xs a non-problem.
Thank you, in advance!
LLAP
Nacon4
And yes, it can be used with DD3, but DD3 isn't required. If you saw my battlemap in Shessar's competition, that was a mix between SS3 and DD3.
LLAP
Nacon4
