How to set the floor of a circle?
I am drawing out a castle that has several circular towers. I drew circles using the circle tool, and the circle is black on the inside. How do I set the floor to the same as the rooms that were drawn?
To change the circle to look like other floors:
- Right-click the Change Properties button and select Change like draw tool from the pop-up menu.
- Right-click.
- Pick the drawing tool for the floor you like. If necessary, you can check the Display sample checkbox to see see thumbnails of each tool.
- Select the circle
- Right-click and select Do It from the pop-up menu.
It seems to me that sometimes the entity (in this case a circle) will change to the correct layer but I don't know how certain that is to happen so I always change the entity to the correct sheet and the correct layer immediately before or after I perform the above steps.The Command bar changes to read, Drawtool name [dialog]:.
This always performs the default action listed in the square brackets. In this case, it opens the appropriate dialog. The Select drawing tool dialog displays.
As soon as you click a drawing tool, the dialog closes and the Command line changes to read, Select entities (0 picked):.
The circle is highlighted and the Command line now reads, Select entities (1 picked):.
The circle will take on the properties of the drawing tool you chose!
I hope that helps,
~Dogtag
