Catalogues...
ProFantasy 🖼️ 40 images Cartographer
I've made my first catalogue. It has 130 shrubs in it (all sadly about the same but different colours and shapes), and its causing CC3+ to run very slowly.
Is it the number of symbols, or the resolution I've done them at that's causing the problem.
(The symbols are all 2000 x 2000 pi... I did it without really thinking!)
Check out pp. 87-89 of the Tome of Ultimate Mapping, particularly pp. 87-88. They discuss symbol resolution, including how to have CC3 create multiple resolutions of your imported PNGs (VL, LO, HI, and VH).
Cheers,
~Dogtag
I imported them all at 40 pixels per map unit and did everything according to Joe Sweeny's instructions - including generating multiple resolutions. The trees appear to be ideally sized (which was a bit of a surprise, since I guessed)
I'm thinking the MC map is already a little on the slow side, and having a really large symbol set active on top of all the other symbol definitions is maybe the straw that broke the camels back?
Presuming raster symbols are handled similarly, if not the same (and yes, I'm guessing), CC3 should store one symbol definition per symbol that had been placed in the map. If you use a symbol more than once, CC3 does some behind-the-scenes magic to reference that symbol. This would be much the same way that an entity using a bitmap fill made of a 50x50 px image doesn't contain multiple copies of the bitmap fill file. It uses the bitmap fill once and then duplicates it where needed.
That said, duplicating a bunch of stuff, particularly of the enormous size of your MC map, does eventually eat up memory and resources. But it shouldn't have anything to do with the catalogue itself, or the unused symbols it contains.
Cheers,
~Dogtag
Thanks Dogtag
If so, anything you previously deleted could still be stored in the map (well, one instance of each symbol, that is).
Cheers,
~Dogtag
To get technical: where Windows, ans some other operating systems, place items into memory is kept in a pointer data base in memory. This tells the computer where the software starts and ends. After several hours, or days depending on the software and operating system, the operating system thinks no room left in ram to place a program and/or data... so it pages data and programs in and out of the ram. This is very slow. A shut down, and most of the time a reboot, resets this temporary in ram only database, and all is well again... until it does it again.
If that isn't it, and likely a purge should fix it.
I already purged the unused symbols anyway.
I'm going to take a bit of a break and get this book finished now, but I will be back.
Thanks to all of you and your help. It won't be wasted
