Finding properties
ProFantasy 🖼️ 40 images Cartographer
I have a map with at least a hundred sheets on it, so trying to work out what sheet something is on by hiding them all and then unhiding them one by one can be a bit time consuming. I think I once knew a way to find out the properties, and therefore which sheet something was on, but I can't remember how you do it now because I haven't used it for so long.
Does anyone know?
Does anyone know?
Info --> List then select the object(s) you want to check then , Right click --> Do it. and a window opens up with all the info about the selected objects
Thanks Mappy
