Small City of Halinyn
Here is a picture of the city of Halinyn in the Kingdom of Mirilandi.
Halinyn is a relatively minor city, but it is a border city with Gibeon to the south, and is a garrison station for the Royal Army of Mirilandi guarding the southern border.
I might suggest a boat or two. :-)
You might not have seen it, but the title is escaping the box just a little bit.
Other than that its pretty cool
I'm trying to figure out how I will do cemeteries in the two churches...
Read the 'Taming Text' chapter in the User Manaul for more information about this.
In the manual it explains that CC3 has no control over the way text grows or shrinks at different zoom levels, because its appearance is controlled by Windows - the fonts being Windows fonts. A suggested solution is that you make text that is placed in boxes centre justified, and then adjust the size of the font until you don't have this problem when you render.
If you want to edit existing text you can use the Edit/Text/Edit text... option, select the text and right click for "do it". You can change the alignment to centre justified by clicking the properties button, which means your text will overhang the box by the same amount on either side - making it easier to adjust the font to a more suitable size for rendering
