White Lines around Buildings SOLVED!
Does anyone know what might be causing all the new buildings I paste into this map to have white lines around them?
As you can see from the smaller brown buildings I wasn't having this problem before, but I am now that I'm trying to add the larger buildings on the right of the shot.
I should maybe add that I think the file could be corrupted, because I had a crash and when I reopened it there was a single coordinate point about five times the size of the map off to the top right corner that caused it to nearly disappear when I hit the zoom to extents button. I managed to find it and delete it (whatever it was), but I'm thinking that wasn't the only thing wrong with the map that made it crash in the first place.
    Can you see them if you save in png format? Sometimes i can see things...like a sheet "liner" i put between sheets to prevent the triangle distortion on multiple beveled sheets, but when i save as png they are not visable.
    Oh they render all right. I had to mention them in the image I uploaded to the Guild yesterday because they were visible.
    I'm thinking that I may have to go back a couple of versions and lose a couple of days work (he-he won't that be peaceful for you all!). Rather that, though, than end up with a file that's falling apart before I've even half done with it.
    Its ok. I've worked it out now.
    If you look at the image below you can see a collection of buildings, all with different colours edging them. The colour depends on the drawing colour you just happen to have selected at the time you paste the building!
    I don't think it affects more than just the collection shown, but it means I'm going to have to make sure I have a neutral grey brown selected whenever I paste any more of the same type.
    By some incredible coincidence whenever I was pasting all the other houses in the city before these few on top I had the colour set to black (which explains the hard lines around some of them)
    I don't know why its happening, it just is, that's all.
    edited August 2016
    It might be the building color being slightly off. Try to hide the STRUCTURES (COLORS) layer.
    That did the trick. Thanks Monsen :D
    Is there any reason I can't just delete that layer if its only causing me a headache?
    That AND the STRUCTURES (OUTLINE) - which is causing another headache - giving all the buildings a double image like they are out of focus.
    edited August 2016
    Deleting it would only mean that it would be recreated next time you place a building, so hiding it is better.
    Note that the color you see is intended to use for informational purposes, CC3 can show your city with building colored by their type/functionality or whatever you decide really. Because of this, there is a colored polygon below every building, which is normally obscured by that building. Bu hiding that layer, you also hide these polygons.
    Building symbols in CD3 are actually quite complex entities, with a lot of functionality provided, and not just simple images.
    You have no idea just how many headaches you have just solved!!!
    THANK YOU!
    Always happy to be of assistance.
    Happy mapping :)
    You're a star, Remy :D
    I have noticed that some symbols, bitmap fills, and paths for roads, use the current color for an outline. So make sure the current color, in the color requestor, works with the symbols, road, etc. that you are about to do.
    How do I know this ? Yellow or orange outlines of roads. Couldn't figure out why, until I noticed the current color in the color requestor/select color was yellow.
    I don't notice this because I always use the freehand drawing tool to draw everything on the map - roads, areas of fill - everything. I've never had an outlined fill because I use the "path to polygon" command and turn my freshly drawn shape into an area of fill. Roads - I just draw a line with the freehand tool (or sometimes the curved line tool) and set the thickness to however wide I want the road to be.
    In both cases, the area and the road assume the active fill, so I always make sure I have the right one for that particular filled area or road before I start drawing.
    I think some of the special tools for drawing roads and areas of fill have an outline setting on them which makes it automatic. If you just want to get rid of the visible outline on an area of fill, try changing properties and checking the little tick box that says something like "hide outline if filled".
