Adding floors with Dungeon Designer CC3+
I've created a bunch of rooms (and then filled them with items) with the "Floor - background" box unchecked and have now determined that that was a mistake.
Is it possible to select all the rooms and add floors to them?
Rooms aren't really "room objects." They're merely floors with walls. When you create rooms without floors, you really just created walls. There's no "Add floor" function that will automatically draw a floor for selected walls.
Monsen's solution, above, can help you get it all done "at once" and it's really not as complex as it may seem when reading it. Here's a quick tip.
To copy all your walls to the Floors layer:
- Right-click the Copy button (on the left) and select Copy to Layer from the pop-up menu.
- Right-click again and select Layer
- Right-click again (I know but, yes, again).
- Click the WALLS layer (that's a normal left-click this time).
- Click Ok.
- Right-click and select Do it from the pop-up menu.
- Right-click.
- Click (that's a normal left-click this time) the FLOORS layer.
- Click Ok.
To copy all your walls to the Floors sheet: (after copying them to the Floors layer)The command line at the bottom now says Select entities (0 picked):
The command line at the bottom now says Layer name [dialog]:"
The Select Layer dialog displays.
A gray bar highlights the layer name. If you clicked the checkbox (you don't have to), then the box checks as well.
The selected walls highlight and the command line at the bottom now says Select entities (X picked):, where "X" is the number of wall entities selected.
It looks like nothing happened, but it did. The command line now reads, Command [LAYERCPY]:
- Right-click the Copy button (on the left) and select Copy to Sheet from the pop-up menu.
- Right-click again and select Prior
- Click the FLOORS sheet (a normal left-click).
- Click Ok.
If you hide everything but the FLOORS sheet, you should see the walls that you copied there. You can then follow the rest of Monsen's instructions to convert the copied walls to floors.The command line at the bottom now says Select entities (0 picked):
The Drawing Sheets dialog displays.
A gray bar highlights the sheet name.
It looks like nothing happened, but it did. The command line now reads, Command [ COPYSHT]:
I hope that helps,
~Dogtag
