DD3 symbol catalogs instead of CC3
Hello!
I am creating an overland map, but when I go to place mountains, etc., the catalog is empty. Checking under settings show DD3 as the filter. I see no way to change this. Anyone have any ideas?
Thank you!
Thank you!
I also suggest clicking on Options and Expand all collections, Show symbol size, and Number of columns to 2 or 3. Click okay.
You can tell what mode you're in if you look at the menu bar. If you're in CC3+ overland mode, the third menu option from the right is "Overland." If you're in DD3 dungeon mode, the third option from the right is "Dungeon."
If, in fact, you're in the right mode but getting the wrong result, let us know EXACTLY which template you used to start the map. It also is possible that a macro in the template is corrupted. That can be fixed easily, if one knows which template needs to be fixed.
