All my polygon tools have stopped filling. I only have an outline even though I select FS:SOLID. I have been working to get my solid fill back for hours. I sure could use some help.
JimP Thanks for the suggestion. Unfortunately that didn't solve the problem. No matter what fill style i select: Brush, Hatching, Bitfiles etc.. the polygons will not fill. I have tried the CHANGE and EDIT properties also. Any other ideas? Thanks again for your time.
That SOLVED it. I had a 4 in the 'W' (line width). I am not sure why that would stop the fill but it did. non-intuitive for sure. Thank you for your great advice. CharlesWayneRobinson You saved the day!!!
jslearner said:That SOLVED it. I had a 4 in the 'W' (line width). I am not sure why that would stop the fill but it did.
If the line width is set to greater than zero then the fill style fills the line instead of the shape formed by the line. Dungeon walls are an example of how this looks in practice. So, for a shape to be filled with the fill style, the line width for the shape must be set to zero.
Cheers,
~Dogtag
