Is there an Overland style like Ordnance Survey maps?
Anyone aware of a CC style like that used by Ordnance Survey for their 1:50000 maps?
    Symbol Set 3 has a nn overland style that is based on Ordnance Survey. The "problem" with these modern styles is usually that they don't use much in the way of symbols and instead use simple lines and areas mostly. Their beauty comes from the high amount of detail, and recreating that is a lot of time-consuming work.
  • Ralf - I find symbols inappropriate for large area maps but thanks for your guidance. Using symbols for contours or cliffs does not work in detailed maps.
