Character Artist 3+ Setup
I have purchased Character Artist 3+
I am using Window 7
The setup seems to be different than the other updates that I have done
Can anyone give me the setup directions for this?
Thank you for any help that you may be able to provide
  • VintyriVintyri Newcomer
    1. Also download the patch CA3ForCC3PlusFix.exe, if you haven't done so yet.
    2. Turn off anti-virus software
    3. In the Windows Explorer, click the file name CA3Setup.exe with the right mouse key.
    4. Pick the option "Run as Administrator". The install routine should start.
    5. After the installation is finished, in the Windows Explorer, click the file name CA3ForCC3PlusFix.exe with the right mouse key.
    6. Pick the option "Run as Administrator". The install routine should start.
    7. When the installation is done, turn your anti-virus software on again.
  • edited May 2016
    Vintyri,
    I think I figured it out - thanks!
    Posted By: CharlesWayneRobinson
    I click on the link under Downloads & Upgrades and I saved the zip file to my desktop.
    I then extracted it to my desktop.
    I did not have a option for CA3Setup.exe
    But you should have a folder from your zip file called "CA3," and inside that folder, you should find a file named "CA3Setup.exe."
    There are two of them
    1. Application
    2. Windows Installer
    Where do you have this? I'm not sure what you're referring to.
    Right clicking on them does not give me the option for Administrator
    You get that option only when you click the .exe files.
    If this message hasn't cleared things up, for the next step I need to know EXACTLY what you get when you unzip the downloaded file CA3Setup.zip.
