Map Transfers...
So I made a nice map outline using 18 x 15.5 dimensions I believe. I know that is massively colossal. Is there anyway to downsize this same map to different size dimensions and keep the same map outline? Or any other way to cut out parts of the map to put it on a new canvas with smaller dimensions?
Anyway, to resize the entire map, you should unfreeze (thaw) all layers, then just enter SCALE [enter] in CC3's command bar, followed by a (to select all), then d (for do it). Now enter the scale factor, and the scale center (Usually, accepting the default by just hitting enter is fine). Redraw.
To get parts of the map, all you need to do is to Edit --> Copy, then select the entities, and past them onto another map. Make sure you follow all the prompts in the command bar though. Many people forget to look for instructions there, and gets confused as to why the clipboard is always empty.
