Perspectives 3 Bugs
1. No windows in the Bitmap A style?
2. *** FIXED *** When exporting as a rectangular png, the fills no longer align properly. (see attached)
3. Hyperlink Broken: The link to the perspectives 3 guide on the Perspectives welcome page points to a file name that has spaces in it. The actual file in the documentation folder does not have spaces.
4. At the point shown in the screen shot below, the "Symbol Style Toggle" icon calls up a blank.
5. ***NOT A BUG*** Not sure if it is a bug or working as intended: 3d Projection: Shaded Polygon cannot be converted directly to floor. Requires exploding the original back to components, or selecting "leave as original" in dialog.
6. Circular Room Walls render weirdly, as if the projection creates hollow paperfold.
7. Here's another one. Right click on the draw room option, left click room options. When the isometric rooms menu comes up I select the help menu and...nothing. You can click on OK or Cancel buttons and they work but not the help menu.
8. In Perspectives Settings>>Advanced dialogue, when changing the the Floor bitmap settings, the fill style on the Preview does not change until another option in the dialogue is clicked.
9. Not sure if this is a CC3+ or Perspectives 3 specific. When creating a new fill style the Fill Style Name box shows corrupted. The user creates a new fill style and gives it a name. Then does a find for a bitmap. If the user click the Fill Style Name box again, before clicking OK, the box shows as gibberish names. See image here.
10. Errors in the Essentials Guide: See here, here, and here
11. *** FIXED *** There is a problem with user added fill styles not aligning properly when using the House drawing tool. SEE HERE
12. 3D Projection does not work when a polygon is drawn using the All Map Drawing Tools button. See THIS THREAD.
«13
