Not Sure what's going on here...
LadieStorm
🖼️ 50 images Surveyor
I'm remaking my Ardenvale map, and remaking my river to get my scaling right. Well I've run into another interesting snag... not sure if it's just what I'm seeing, or if it's not working correctly.
I'm on my river mask stage (see Shessar's streams tutorial), where I'm supposed to add the edge fade, inner to my 'white water' so it looks like it's flowing over my river debri. I've added the edge fade, inner to my flow through... click okay... nothing happens. Well, I figured I put it on the wrong sheet again(I make that mistake a lot), so I go back into sheets and effects, and as far as I can tell, it's on the correct sheet. I click okay, go back... nothing happens.
So I start systematically hiding my sheets, to isolate where my flow through actually is. Here's the funny thing. After I hide all of my sheets but the river mask, which is where my white water is supposed to be, I click okay, and there is my white water, just where it's supposed to be with what looks like an edge fade inner on it! I think 'ok, it's working now.' So I go back and unhide all of my sheets, and click okay, and look at my full image. The white water, once again, shows no edge fade, inner.
I must have hit something wrong somewhere, but I'll be buggered if I can find out what I did... of if it's me, the machine I'm on, or the program. Any ideas?
Here's the .fcw
Here's the .fcw
Or should I ask if that explains my issue better?
now that I have everything intsalled on my new laptop, I've opened it up, and I'm still having the same problem. I get the inner edge fade, if I hide all my sheets but the river mask. Here are my fcw's
I have NO IDEA how the river mask showed up on the river rocks... but it's fixed.
Now I can get back to constructing this map! I'll post the update tomorrow... it's time for me to go home now...
