The dimensions might not show in the template information, because it can be dynamically adjusted in the New Map wizard. But you can always use "Distance" from the Info menu to measure the height and width of your map.
Oh well, my continental map is about 170 miles shorter than what my country map is. I guess I will write that off to medieval engineering. Thanks for the tip Ralf, at least now I know.
Try this:
- Select File>Drawing Properties from the menu bar.
- Click the Map notes button.
- Select Template and then click Edit.
Not sure if that'll give all the info you're looking for about the template, but it may be worth a shot.The Drawing presets dialog displays.
The Select Note dialog displays.
The Edit Text dialog displays, showing information about the template.
Cheers,
~Dogtag
