(ot) laptop failure
🖼️ 280 images Cartographer
My laptop has failed. Using cell phone to post. Be back next week. Unable to reach email.
edit: We should whisper fix ideas so as to not clog up the Profantasy mapping forums.
I did a web search, and found lots of Asus laptop owners are being hit by this. Its their eSupport BIOS upgrade that is failing. There are a number of posts on the Asus forums, and no help there.
I'll put the laptop hd in an external case, make sure I have everything copied over, and then use it for storage.
Ah well, I'm back and this can sink.
So I removed the CC3 and Update 11install from Program Files. Went into File Explorer and created C:\Profantasy\CC3\ folders. Reinstalled.
I installed in the folders I wanted it to be in. FastCad cannot find Menu. So I checked the registry and found only one entry for CC3 being in Program Files. I deleted it, and rebooted. Still no Menu found. I can see the files in the C:\Profantasy\CC3\ folder.
I'm currently doing a repair of CC3 and see if that works. I'll let you know.
