Tome of Unlimited Mapping PG 280 - City Walls
Trying to work through the tutorials (and understand what they are trying to teach) and can't quite get mine to match the example.
On pg 280 of the ToUM it explains a method for editing the City Wall 20' drawing tool to create a drawing tool for doing a circular tower. Followed the directions and it sort of works except mine doesn't quite look like the example. The example from the Tome is on the left and mine is on the right. For whatever reason the central part doesn't seem to want to merge as in the example.
Any suggestions on where to start troubleshooting this problem. I played around in the sheets section and by moving WALLS TOP above WALLS I can get it merge the center section but then the effects are all screwed up.
thanks
thanks
Nice, thank you it was driving me up the wall. Annotated my copy of the Tome with the change
