Squares in FT
Parts of my map has squares (see image) I have tried smoother and rougher terrains, raise and lower terrains with anywhere from 10 to 100 or more. But I can't them to smooth out. I would like to just set the altitude and cover an area. is there a way in FT to do that or do I have to export it to a different program?
Thanks
Thanks
Be sure to check out http://www.fracterra.com/CGTutorial/index.html for some hints on how to avoid such problems.
[FT3] Basic Editing is a good place to start.
Basically, the best way to avoid such artifacts is to use Prescale editing commands, a big brush (~256) and a small value. Also, if you are using selections, feather them before using editing commands.
using the freehand tool and using the global offset worked. Thanks for the idea.
