Bitmaps in map tracing
                    Hi all
I have a problem that probably sounds stupid. I know how to trace over imported bitmaps and now got quite good at it. However, some of the maps I need traced need some changing, so I need to get rid of the original bitmap when I'm done. I can't seem to find out how though. What am I overlooking?
Draw->Insert FileMake sure to place it on an appropriate sheet so you can see it while tracing.
*I'm not sure if Patch 7 fixed this, but whenever I added a new sheet and put an image on it in the past, it would be automatically deleted when CC3 closed the file if I didn't put some other entity on it as well as the image.
If you add a new sheet and don't put anything on it, however, saving and closing the file will still delete that sheet. But that's how CC3 has always worked by default.
