Exporting from FT3 to CC3 - lakes vanish
So, I'm trying to create a world map using Fractal Terrain 3 and then export it into Campaign Cartographer 3. I can fill all the basins into lakes, add rivers... all the stuff I wanted. But when I go to export it, I can't find any way to KEEP the lakes. Since it's water areas above sea level, the contour system loses them, and there doesn't seem to be a Sheets option for lakes.
Am I missing something obvious here, or is there something clever I need to do in order to get everything moved?
So it should be something like this:
Common
Background
land
lakes
Land gets drawn first, then lakes.
Hide one layer at a time until you find the lakes, and then move sheet the lakes to the lake layer.
'Move sheet' command is found by right clicking 'Change Properties' on the left side, and selecting 'Move Sheet'.
