CC3 is misbehaving. Help?
Hello everyone,
Hope you can help.
I have been getting a message saying "No matching draw tool" for most of my DD3 tools. Also, when i try to start the program, sometimes i get a huge screen or large red crosses in the workspace between the toolbars. Any ideas what's going on?
Thanks
Craig
    No matching draw tool means that there are no tools of the selected type in the style you are currently using. Make sure that you are working from a proper dungeon template when using DD3 tools.
    The red X means that the raster image that should be in that position was not found. Since CC3 loads the last map you worked on when starting, this would typically indicate that the image referenced in that map was either moved, deleted, or is currently not available (on a network drive that is currently not connected perhaps?). You can use the Info command on it to figure out the path to the missing image, usually that should provide enough information to figure out what happened.
  • 17 days later
