wood walls?
I can see how to do wood wall if I use the "add room" tool, but I want to add wood walls w/o it being a whole room, or to be able to vary the direction of the grain appropriately.
Any suggestions? When I click the wall tool, I get very limited options; mostly stone.
thanks!
    You'll need to create your own tools if you need a tool with a fill beyond what is premade.
    Creating new tools is really easy. When in the select drawtool dialog, just hit the advanced button, select one of the tools to use as a base, Hit New, give it a nice name (Starting with Wall, ), then make sure your new tool is selected in the list, and hit the properties button. From here you can assign any fill style defined in the template to the tool.
