Two small problems.
I'm having difficulty with two hopefully small things.
First, I'm having a lot of difficulty putting anything on the layers/sheets where I want them to go. I pick the tool, then re-select the sheet and the layer and the minute I place a symbol or draw, it is back on the default layer for that type of item. I have. Some of the terrain drawing has a check box for Insert on current layer. I've checked that and it doesn't matter.
Second, I need to scale terrain default, grasslands and terrain default, swamps down but they simply will not scale. Terrain default forest scaled just fine. What might I be doing wrong?
Thanks in advance.
Thanks in advance.
To scale terrain fills, you need to open up the fill style dialog, go to the Bitmap Files tab, find the correct fill type (It might not be named the same as the drawing tool) and change the scaling of it.
